11-Garnet
Jan 23, 2025 4:50 PM UTC
Unable to Replace the Default View in Windchill – Permission Issue?
Hello everyone,
I am currently facing an issue with modifying the default "Required" view in Windchill. Despite having wcadmin permissions, I cannot replace or update this system-level view. Here's a detailed overview of what I've tried and observed:
What I Need:
I want to replace the existing default "Required" view with a custom configuration that better suits my requirements. I do not want to create a new view; my goal is to overwrite or modify the existing one.
The same thing for Edit Multiple Objects
Steps I Followed:
  • I exported the "Required" view configuration to an XML file from Windchill.
  • I added the following TableColumnDefinition to the XML file:
<TableColumnDefinition>
 <name>IBA|fr.satys.plm.SecondaryReference</name>
 <locked>false</locked>
 <sortNumber>0</sortNumber>
 <treeColumn>false</treeColumn>
 <sortDescending>false</sortDescending>
 <hidden>false</hidden>
 <width>0</width>
</TableColumnDefinition>
  • I imported the updated XML file back into Windchill to apply the changes.
  • After completing the import, I refreshed the page to check if the changes were applied.
  • The newly added column IBA|fr.satys.plm.SecondaryReferencedid not appear in the "Required" view as expected.
NB:
When I modified the <name> of the view in the XML file (e.g., changing it to a new name) and imported it, I was successfully able to see the newly created view with the name I provided.
However, this is not the result I want — I need to modify the existing "Required" view directly, not create a new one.
⚠️And I can confirm that I am not even able to delete the existing "Required" view and replace it by importing my modified version.⚠️
Any guidance or insights from the community would be greatly appreciated!
Thank you in advance!
Fadel
23-Emerald II
Mar 13, 2025 8:57 AM UTC
Salam Si Brahim,
Why don't you just edit the view from the UI and add the attributes Needed  :
Buiꓘa
