Nov 24, 2023 9:24 AM UTC
Unable to see ChangeActivity in ChangeNotice after migration.
Hi All,
Currently have migrated changeorder, changeactivity and changerecord. Along with this used table IncludedIn2 and CHANGERECORD2__761153863 for links.
All loading turned to be successfull.
Able to see CN in UI of WC however, unable to see CA for that CN.
Is there something missing to be done?
Thanks in advance
avillanueva
23-Emerald II
Nov 24, 2023 7:48 PM UTC
What was the method you used to migrate this records in? Can you explain and provide examples?
DKWc15-MoonstoneAuthor
Nov 26, 2023 6:43 AM UTC
Using WBM
avillanueva
23-Emerald II
Nov 27, 2023 12:58 PM UTC
IncludedIn2 is the right table that links Change Notice to Change Activity. You should check that BRANCHIDA3A5 matches your change notice Branch id and same for BRANCHIDA3B5 matches branch id for Change Activity.
ChangeRecord2 links resulting items to the Change Activity. It should look like below.
