Feb 16, 2023 10:42 AM UTC
Unable to start DataLoadController while loading WTDocument using WBM.
Getting Following ERROR but not generating any logs for that.
EBUG : com.ptc.windchill.migration.wbm.util.ReconcilationHelper - Query to be run - SELECT staging.SEQUENCENUMBER AS SEQUENCENUMBER FROM INT_WTDOCUMENTVERSION staging WHERE staging.MIGRATED =50 AND staging.SEQUENCENUMBER IN (SELECT A278.SEQUENCENUMBER
FROM INT_WTDOCUMENTVERSION A278
INNER JOIN INT_WTDOCUMENTMASTER A71 ON A278.MASTERREFERENCE=A71.SEQUENCENUMBER WHERE A71.BATCH_ID=1
DEBUG : com.ptc.windchill.migration.wbm.util.ReconcilationHelper - Releasing Connection from staging Queue
DEBUG : com.ptc.windchill.migration.wbm.util.ReconcilationHelper - Connection added back to queue
DEBUG : com.ptc.windchill.migration.wbm.util.ReconcilationHelper - Connections with Staging database after releasing one Connection 15
DEBUG : com.ptc.windchill.migration.wbm.util.ReconcilationHelper - Getting Connection
INFO : com.ptc.windchill.migration.wbm.util.ReconcilationHelper - Total Connections with Staging database are: 15
DEBUG : com.ptc.windchill.migration.wbm.util.ReconcilationHelper - Staging live connections 3
DEBUG : com.ptc.windchill.migration.wbm.util.ReconcilationHelper - Query to be run - SELECT staging.SEQUENCENUMBER AS SEQUENCENUMBER FROM INT_WTDOCUMENTMASTER staging WHERE staging.MIGRATED =50 AND staging.SEQUENCENUMBER IN (SELECT A71.SEQUENCENUMBER
FROM INT_WTDOCUMENTMASTER A71 WHERE A71.BATCH_ID=1
DEBUG : com.ptc.windchill.migration.wbm.util.ReconcilationHelper - Query to be run - SELECT staging.SEQUENCENUMBER AS SEQUENCENUMBER FROM INT_WTDOCUMENT staging WHERE staging.MIGRATED =50 AND staging.SEQUENCENUMBER IN (SELECT A280.SEQUENCENUMBER
FROM INT_WTDOCUMENT A280
INNER JOIN INT_WTDOCUMENTVERSION A12931 ON A280.VERSIONREFERENCE=A12931.SEQUENCENUMBER
INNER JOIN INT_WTDOCUMENTMASTER A71 ON A12931.MASTERREFERENCE=A71.SEQUENCENUMBER WHERE A71.BATCH_ID=1
DEBUG : com.ptc.windchill.migration.wbm.util.ReconcilationHelper - Calling service to find source and target object map...
WARN : com.ptc.windchill.migration.wbm.util.ReconcilationHelper - No result from the server!
WARN : com.ptc.windchill.migration.wbm.util.ReconcilationHelper - Nothing is return from the process thread!
16/02/2023 11:50:21 INFO core.CIOTHandler - Start processing: [WTDocument]
16/02/2023 11:50:21 INFO core.CIOTHandler - Start processing definition: com.ptc.wbm.worm.core.Definition|1509890151|General|[Container=com.ptc.wbm.worm.core.Worm|604990529|WTDOCUMENT|Default]
16/02/2023 11:50:21 INFO raw.CIOTRawDataHandler - WTDocument loaderQuery:SELECT A71.DOCTYPE
,A71.NAME
,A71.SERIES
,A71.CONTAINER_ORGANIZATION_NAME
,A71.CONTAINERTYPE
,A71.CONTAINER
,A71.ORGANIZATION_NAME
,A71.CREATEDDATE
,A71.MODIFIEDDATE
,A71.OBJECTNUMBER
,A71.BATCH_ID
,A71.WBMSOURCEDESCRIPTION
,A71.WBMSOURCEIDENTIFIER
,A71.MIGRATED
,A278.MASTERREFERENCE
,A278.REVISION
,A278.MIGRATED
,A280.DEPARTMENT
,A280.DESCRIPTION
,A280.DOCTYPE
,A280.VERSIONREFERENCE
,A280.TITLE
,A280.FOLDERPATH
,A280.FORMAT
,A280.ITERATION
,A280.ITERATIONNOTE
,A280.CREATEDBY
,A280.MODIFIEDBY
,A280.LIFECYCLE
,A280.LIFECYCLESTATE
,A280.CREATEDDATE
,A280.MODIFIEDDATE
,A280.TEAM
,A280.TYPE
,A280.SEQUENCENUMBER
,A280.WBMSOURCEDESCRIPTION
,A280.WBMSOURCEIDENTIFIER
,A280.MIGRATED
INNER JOIN INT_WTDOCUMENTVERSION A278 ON A280.VERSIONREFERENCE=A278.SEQUENCENUMBER
INNER JOIN INT_WTDOCUMENTMASTER A71 ON A278.MASTERREFERENCE=A71.SEQUENCENUMBER WHERE A71.BATCH_ID=1 AND (A280.MIGRATED IN (0,1,52)) AND (A278.MIGRATED IN (0,52,5,7,70,72,9,90,92)) AND (A71.MIGRATED IN (0,52,5,7,70,72,9,90,92))
ORDER BY MASTERREFERENCE,VERSIONREFERENCE
