8-Gravel
Apr 23, 2024 3:50 PM UTC
Unable to upload files in Windchill PDMLink 12.0
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.0
Uploading any file will result in an error that a file of the same name already exists in the vault. Reseeding sequence value as shown here:
https://www.ptc.com/en/support/article/CS374128
did not work. Deleting the files in the current folder from the sequence value onward temporarily resolves the issue (but probably leads to unwanted data loss)
Here are the errors that I faced
2024-04-23 18:17:51,471 ERROR [ajp-nio-127.0.0.1-8010-exec-5] wt.objectstorage.ContentFileWriter - This file cannot be saved because a file named "E:\Vaults\defaultsystemrootfolder\defaultsystemrootfolder_Folder_234\000000011d115e" already exists.
2024-04-23 18:17:51,487 ERROR [ajp-nio-127.0.0.1-8010-exec-5] wt.fv.uploadtocache - (wt.fv.fvResource/63) wt.objectstorage.exception.ContentFileAlreadyExistsException: This file cannot be saved because a file named "E:\Vaults\defaultsystemrootfolder\defaultsystemrootfolder_Folder_234\000000011d115e" already exists.
at wt.objectstorage.ContentFileWriter.storeStream(ContentFileWriter.java:106)
at wt.fv.uploadtocache.DoUploadToCache_Server.storeContentInVaultOnMaster(DoUploadToCache_Server.java:630)
at wt.fv.uploadtocache.DoUploadToCache_Server.storeSingleFile(DoUploadToCache_Server.java:1944)
at wt.fv.uploadtocache.DoUploadToCache_Server.doMultiPartUploadToCache_Server(DoUploadToCache_Server.java:1728)
at wt.fv.uploadtocache.DoUploadToCache_Server.doUploadToCache_Master(DoUploadToCache_Server.java:133)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at wt.httpgw.HTTPServer.processRequest(HTTPServer.java:346)
at wt.httpgw.MethodRequestHandler.handleRequest(MethodRequestHandler.java:88)
at wt.httpgw.HTTPGatewayServlet.serviceWithoutFilters(HTTPGatewayServlet.java:336)
at wt.httpgw.FilterChainImpl.doFilter(FilterChainImpl.java:94)
at wt.session.SessionContextDestroyer.doFilterInternal(SessionContextDestroyer.java:136)
at wt.session.SessionContextDestroyer.doFilter(SessionContextDestroyer.java:184)
at wt.httpgw.FilterChainImpl.doFilter(FilterChainImpl.java:81)
at wt.httpgw.HTTPGatewayServlet.service(HTTPGatewayServlet.java:235)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:733)
Apr 23, 2024 5:39 PM UTC
I recommend you run remove unreferenced files from vault and select the choice to archive instead of delete so they can be restored if necessary.
https://www.ptc.com/en/support/article/CS56539
avillanueva
23-Emerald II
Apr 23, 2024 8:02 PM UTC
@SWeiler_9940261 tip is good. Strange that you had that issue. Was there a DB rollback or other issue? what should happen is that the file counter which makes the filename should continually advance forward. Its important to keep database and vaults in sync. If the database was ever behind the vaults, this can occur.
jbailey
18-Opal
Apr 23, 2024 9:41 PM UTC
Might also be worthwhile to open the file in the vault with a text editor to see what kind of a file it is. If it is a Creo file, it will have the CAD header and what not. then back up the file just in case it is still needed for some reason and wasn't saved elsewhere.
I probably wouldn't do a remove unreferenced files just yet because it is unnecessary to troubleshoot/fix this issue.
