Sep 12, 2022 8:52 AM UTC
Unable to upload WTDocument content via rest
I am getting the following when I try to run UploadStage3Action
 "error": {
 "code": null,
 "message": "Content holder must be checked out for content upload"
Not sure what I am doing wrong.
Here is what I am passing in the body for UploadStage3Action
 "ContentInfo" : [
 "StreamId" :726306,
 "EncodedInfo" : "726306%3A5184%3A779025%3A726306%3ANONE%3A1",
 "FileName" : "TOC.json",
 "PrimaryContent" : true,
 "MimeType" : "text/json",
 "FileSize" : 5184
URL used : https://<WCURL>/Windchill/servlet/odata/DocMgmt/Documents('OR:wt.doc.WTDocument:15196389')/PTC.DocMgmt.UploadStage3Action
For UploadToCache Server
I used the following body data
-----------------------------boundary
Content-Disposition: form-data; name="Master_URL"
https://<WCURL>/Windchill/servlet/WindchillGW
Content-Disposition: form-data; name="CacheDescriptor_array"
726306:726306:726306
Content-Disposition: form-data; name="0000006124"; filename="TOC.json"
eyJUYWJsZU9mQ29udGVudHMiOn#TRUNCATED_DATA##
-----------------------------boundary--
Here is data obtained from UploadStage1
 "@odata.context": "$metadata#CacheDescriptor",
 "value": [
 "FileNames": [
 726306
 "FolderId": 779025,
 "ID": null,
 "MasterUrl": "<WCURL>/Windchill/servlet/WindchillGW",
 "ReplicaUrl": "https://<WCURL>/Windchill/servlet/WindchillGW/wt.fv.uploadtocache.DoUploadToCache_Server/doUploadToCache_Master?mk=wt.fv.uploadtocache.DoUploadToCache_Server&VaultId=746601&FolderId=779025&SSC=1&CheckSum=1452612&sT=1662971140&sign=LVngsXMgfu0R%2BRUmzVlXcmLX2%2FmQeaaXSwnyM5o0IEk%3D&site=https%3A%2F%2<WCURL>%2FWindchill%2Fservlet%2FWindchillGW&AUTH_CODE=HmacSHA256&isProxy=true&delegate=wt.fv.uploadtocache.DefaultRestFormGeneratorDelegate",
 "StreamIds": [
 726306
 "VaultId": 746601
 "@PTC.AppliedContainerContext.LocalTimeZone": "UTC"
avillanueva
23-Emerald II
Sep 20, 2022 4:37 PM UTC
Does this article make sense to you?
https://www.ptc.com/en/support/article/cs305415?language=en&posno=2&q=update%20document%20via%20REST&source=search
Indicates first step is to check out the document which is what the error message is saying.
