6-Contributor
May 23, 2025 10:10 AM UTC
Understanding the function of "Create a new representation" and "Republish"
Version: Windchill 11.1
Use Case: I want to understand what happens when I 1. Create a new representation of an already published CAD module. 2. Republish an already published CAD module. What is the exact difference between the 2 functions.
Description:
I want to understand the use of creating a new representation in Windchill. If a design engineer is currently working on a child CAD module and makes some changes in it, then how to make sure they are also updated in the Top level assembly. Should I create a new representation or should I just republish the Top level assembly again in Windchill to view the recently updated Top level assembly. Im new to Windchill and it would really be very beneficial for me to learn as to how the Top level assembly gets updated when the child parts are updated. Otherwise i will be spending a lot of time in simply generating new/updated Top level assemblies again and again.
Thanks in advance for your reply !
avillanueva
23-Emerald II
May 27, 2025 2:16 PM UTC
If you are using latest for the representation definition, yes, it can be changing frequently. We used as-stored which uses a the check in baseline so its fixed from lower updates. To answer your question about creating new vs republish, your call, both achieve the same result. You can have any number of representations listed which can be done by using "Create new" and giving it a different name. It does not impact previous publishing. Republishing regenerates an existing representation such as the default if you only have one. Depends if you want to keep old ones when generating an update. There are also carry forward options that can be configured as well as position assemblies which pull lower representations of components instead of making copies.   I believe there are also schedulers that can be run to regenerate out of date representations (where lower components have been updated). Hope this helps.
18-Opal
May 31, 2025 1:36 PM UTC
@SR_10832839 ,
Republish will use the original configuration and will modify the existing dB entry for the rep and the links from rep to the files in the vault created by publishing.
The dB data beyond the rep and the links will be deleted from the dB and new data will be created and linked to the existing links that connect the rep to the files in the vault.
The original files in the vault will remain but they will be "unreferenced".
Create New Rep creates a second rep independent of the first rep.
So, if you are publishing the existing rep with config Latest republish would get the job done.
Makes sense?
David
Emeritus
Jun 6, 2025 7:09 AM UTC
Hello @SR_10832839,
It looks like you have some responses from our community champions. If any of these replies helped you solve your question, please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
