Nov 18, 2022 6:06 PM UTC
Update comments field after check in is succeeded
Is there a way or possibility to update the check in comments after the part or item is checked in?
May be by the admin, manager or supervisor roll?
Thanks for your comments and advice.
Bert
avillanueva
23-Emerald II
Nov 18, 2022 7:25 PM UTC
Not without customization or DB hacks sql updates.
18-Opal
Nov 19, 2022 4:40 PM UTC
Bert, hi
What you want to do is doable but not OOTB.
Can you describe your use case?
For example, from the Windchill object’s info page an Admin selects an action to update checkin comments and they add/update comments without iterating the object.
Nov 22, 2022 10:27 AM UTC
Hi Graham,
use case:
User is checking in items into the common space and adds comments in the comments field.
After the check in is succeeded there is a need to add some additional information to the comments
which where added during the check in.
At this moment I see no possibility to achieve that.
It would be nice to have this possibility may be connected to a role in Windchill.
May be the Admin.
bert
avillanueva
23-Emerald II
Nov 22, 2022 2:10 PM UTC
What about using the underrated discussion forum? It would not be tied to an iteration but can collect comments and postings about the subject object.
