Jun 3, 2024 1:58 PM UTC
Update IBA value through utility without changing last modified date
Version: Windchill 12.1
Use Case: I've updated an IBA value on Change Request, through a utility. ( not directly on the object through windchill UI). so, it has changed the last modified date of it as well. Is there any way we can revert this and set it back to the previous last modified date?
Description:
18-Opal
Jun 3, 2024 6:18 PM UTC
Do you know what the previous  modified date is?
Or are you asking how to determine what the previous modified date was?
Also, are you asking if there’s a way to not change the modified date when you use your utility or is it just this one case that you want the modified date to revert back to previous modified date?
RG-Alle12-AmethystAuthor
Jun 12, 2024 2:30 PM UTC
I was looking if there is a way to revert back to the previous modified date, but it might not be possible, since the update has already been done.
So, for future updates to an IBA, can we update only the IBA value and somehow persist the last modified timestamp and rewrite the last modified date to the persisted timestamp?
Fadel
23-Emerald II
Jun 12, 2024 2:56 PM UTC
its not recommended ,but  the only way if you are aware of the old value modify date is to run some SQLs after using the tool to set the old date.
Buiꓘa
