3-Newcomer
Jun 17, 2025 2:12 PM UTC
update path
We are using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.2
We have a Windchill 12.1.0.2 system.
We would like to update to version 12.1.2.16.
The upgrade/update path table does not include this initial version.
Can we update this in one step? Or what are the steps to get to the target version?
Maybe upgrade process is needed already in this case and update is not enough?
    avillanueva
    23-Emerald II
    Jun 17, 2025 2:29 PM UTC
    I do find it strange that 12.1.0.anything was not listed but so did @BenLoosli :
    https://community.ptc.com/t5/Windchill/Windchill-12-1-0-x/m-p/790410#M66578%3Fsource=search
    There were short support windows but I suspect you would have no issue jumping to 12.1.2. That fact that you can jump from lower versions to 12.1.2.16 or now 17 is a good indicated that you are likely ok. Keep an eye on support end dates as you will likely need to jump next year too.
    Jun 17, 2025 9:19 PM UTC
    Remember it is the XX,y,2,x versions that are the long term support releases.
    12.0.2.x
    12.1.2.x
    13.0.2.x
