Apr 12, 2017 8:38 AM UTC
Update Query Builder Report - Windchill Shell
Does anyone know what the command is (if there is one) to edit reports in the query builder using the Windchill shell?
Ideally I'd like to be able to completely replace a report already in the Query Builder with a .qml file, but still keep the original report ID.
If this isn't possible, does anyone know the command to just upload a new report to the Query Builder in the form of a .qml file (I'm fairly sure that this is possible as I believe I've done it before)?
Any help is greatly appreciated!
Many thanks,
2-Explorer
Apr 12, 2017 12:41 PM UTC
You can run a command similar to this
java wt.query.template.LoadSingleReportTemplate PSG_Method_RegenReport  /System E:/PSGreports/PSG_Method_RegenReport.xml "/wt.inf.container.OrgContainer=Orgname" -replace
2-Explorer
Apr 13, 2017 9:56 AM UTC
Worked perfect thanks!
