Apr 13, 2024 10:09 PM UTC
update revision
My files are checked in, and I need to update the revision but they file has a line through it
HelesicPetr
Apr 15, 2024 8:40 AM UTC
Hi @LR_9979604
Move your pointer to the red icon HelesicPetr_0-1713170323147.png.
It shows you the error, and you will get idea where the problem is.
I guess that it is a permission issue because you can see the target state.
PetrH
jbailey
18-Opal
Apr 14, 2024 12:55 AM UTC
Means one of two things. You are not in a role authorized to revise the objects, or the objects are in a state that doesn't have a revise transition defined.
HelesicPetr
Hi @LR_9979604
PetrH
Emeritus
Apr 19, 2024 10:18 AM UTC
Hi @LR_9979604
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
