ozclkonur
Apr 16, 2024 1:15 PM UTC
Updating Parts via Patch Method Without Versioning: Is it Possible?
"I want to update using the patch method with this API endpoint: http://************/Windchill/servlet/odata/ProdMgmt/Parts('OR:wt.part.WTPart:*********'), but it warns me that I need to check out first. Is there a way to update the part without checking in or out, without touching versions, etc.? If there is a method, could you explain it?"
Apr 16, 2024 7:57 PM UTC
Unfortunately there is no way to edit any WTPart by WRS without iterating it. Also with java it's not official supported to change an attribute without checkout/checkin.
