May 7, 2018 10:04 PM UTC
Upgrade error executing a JavaMigratorDirective with className=wt.org.PopulateUserFullNameFields
Upgrading from Windchill 10.1 M050 to Windchill 11 M030. This task is failing when trying to configure JNDI enterprise adapter.
The nested exception, AuthentiationException is given below. How can I verify/specify the userid/password to the UpgradeManager?
After the first time providing this information during Gather Upgrade Properties phase, the UpgradeManager UI does not provide a way to verify/re-specify the values.
"Caused by: wt.util.WTException: Error in finding mapping key for "user.cn" in adapter : com.xxxx.hq.xxxpvmflexapp11.XXXADS
Nested exception is: com.infoengine.exception.adapter.IEAdapterException; nested exception is:
javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C09042F, comment: AcceptSecurityContext error, data 52e, v2580"
Thanks for help in advance.
Aug 15, 2018 12:40 AM UTC
Did you get it fixed?
