Feb 12, 2013 11:29 AM UTC
Upgrade failed, how to fix?
I tried to upgrade Windchill with the Upgrade Manager and it looks like something is missing or might run with the wrong version,
could you please help to find and fix the problem?
Failed: Populate the fields Prefix, First, Middle, Last and Suffix in the WTUser table.
UUID: *
IU Description: This migrator uses the current value assigned to the full name and last attributes for a user in the directory server. If the wt.org.populateUserFullNameFields property is set to true, the migrator parses the full name attribute into Prefix, First, Middle, Last and Suffix values, and persists them into the new columns created in the WTUser table. If wt.org.populateUserFullNameFields is set to false, the migrator instead persists the full name and last attributes into the First and Last columns respectively and sets the other name columns as null. For disabled users, full name is calculated from the existing persisted values as "prefix first middle last suffix"; the first column is set to the calculated full name, the last column remains the same, and the rest of the name field columns will be null.
Start Time: 08.02.2013 17:33:58 MEZ
End Time: 08.02.2013 17:33:58 MEZ
Logged Messages:
1. PopulateUserFullNameFields START:***
2. >>> Popluate User Full Name fields is false, populating First column with Full Name and Last Column with last name; prefix, suffix, middle will be null
3. Updating user with id :***
4. Error in java migrator code:
(com.ptc.windchill.upgrade.updates.directives.directivesResource/27) com.ptc.windchill.upgrade.updates.DirectiveExecutionException: Unexpected error executing a JavaMigratorDirective with className=wt.org.PopulateUserFullNameFields.
Verschachtelte Ausnahme ist: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.ptc.windchill.upgrade.updates.directives.JavaMigratorDirective.invokeJavaMigratorApi(JavaMigratorDirective.java:422)
at com.ptc.windchill.upgrade.updates.directives.JavaMigratorDirective.execute(JavaMigratorDirective.java:203)
at com.ptc.windchill.upgrade.updates.IncrementalUpdate.execute(IncrementalUpdate.java:661)
at com.ptc.windchill.upgrade.updates.UpdateRunner.applyUpdate(UpdateRunner.java:281)
at com.ptc.windchill.upgrade.updates.UpdateRunner.executeAllUpdatesIn(UpdateRunner.java:220)
at com.ptc.windchill.upgrade.updates.UpdateRunner.run(UpdateRunner.java:169)
at com.ptc.windchill.upgrade.statemachine.state.MigratorRunnerUpgradeState.execute(MigratorRunnerUpgradeState.java:65)
at com.ptc.windchill.upgrade.statemachine.state.MigratorTableRowCountsUpgradeState.execute(MigratorTableRowCountsUpgradeState.java:46)
at com.ptc.windchill.upgrade.statemachine.state.PhaseEventUpgradeState.execute(PhaseEventUpgradeState.java:50)
at com.ptc.windchill.upgrade.statemachine.state.PersistPhaseUpgradeState.execute(PersistPhaseUpgradeState.java:100)
at com.ptc.windchill.upgrade.statemachine.state.ReportWriterUpgradeState.execute(ReportWriterUpgradeState.java:76)
at com.ptc.windchill.upgrade.statemachine.UpgradeFrameworkStateMachine.run(UpgradeFrameworkStateMachine.java:399)
at com.ptc.windchill.upgrade.statemachine.UpgradeFrameworkStateMachine.main_(UpgradeFrameworkStateMachine.java:786)
at com.ptc.windchill.upgrade.statemachine.DynamicLauncher.runUpgradeFrameworkStateMachine(DynamicLauncher.java:112)
at com.ptc.windchill.upgrade.statemachine.DynamicLauncher.main(DynamicLauncher.java:30)
Caused by: wt.util.WTException: Error in finding mapping key for "user.cn" in adapter : local.test.destrsrvpdm.jndiAdapter
Verschachtelte Ausnahme ist: (com.infoengine.jndi.JNDIResource/40) com.infoengine.util.IEException: Konfigurationsfehler - Anbieter-URL wurde nicht angegeben; Dienstname: "local.test.destrsrvpdm.jndiAdapter". Pr?fen Sie, ob der Dienstname und Laufzeitdienstname richtig sind.
at wt.org.UserFullNameFieldsHelper.readPrincipal(UserFullNameFieldsHelper.java:352)
at wt.org.UserFullNameFieldsHelper.populateUserFullNameFieldsAndUpdate(UserFullNameFieldsHelper.java:128)
at wt.org.PopulateUserFullNameFields.runMigration(PopulateUserFullNameFields.java:39)
... 23 more
Caused by: (com.infoengine.jndi.JNDIResource/40) com.infoengine.util.IEException: Konfigurationsfehler - Anbieter-URL wurde nicht angegeben; Dienstname: "local.test.destrsrvpdm.jndiAdapter". Pr?fen Sie, ob der Dienstname und Laufzeitdienstname richtig sind.
at com.infoengine.jndi.JNDIAdapterImpl.processRequest(JNDIAdapterImpl.java:136)
at com.infoengine.procunit.adapter.Adapter.send(Adapter.java:391)
at com.infoengine.SAK.ObjectWebject.invoke(ObjectWebject.java:262)
at com.infoengine.compiledTasks.file.C$3a$5cptc$5cWindchill_10$2e1$5cWindchill$5ctasks.wt.federation.queryprincipals$2exml.invoke(queryprincipals$2exml.java:100)
at com.infoengine.SAK.Task.invoke(Task.java:1806)
at com.infoengine.SAK.Task.invoke(Task.java:1714)
at wt.org.UserFullNameFieldsHelper.readPrincipal(UserFullNameFieldsHelper.java:317)
... 25 more
Exception:
com.ptc.windchill.upgrade.updates.UpdateExecutionException: Error executing IncrementalUpdate Populate the fields Prefix, First, Middle, Last and Suffix in the WTUser table. (#919772423-1197561275280-14600371-207-10-253-132)
Verschachtelte Ausnahme ist: (com.ptc.windchill.upgrade.updates.directives.directivesResource/38) com.ptc.windchill.upgrade.updates.DirectiveExecutionException: Unexpected error invoking method server code wt.org.PopulateUserFullNameFields.runMigration See nested exception for details.
Verschachtelte Ausnahme ist: (com.ptc.windchill.upgrade.updates.directives.directivesResource/27) com.ptc.windchill.upgrade.updates.DirectiveExecutionException: Unexpected error executing a JavaMigratorDirective with className=wt.org.PopulateUserFullNameFields.
... 23 more
... 25 more
Aug 17, 2017 7:06 AM UTC
Seems like an error in LDAP.
Rehosting process didn't happen correctly.
Check whether the property "wt.federation.org.defaultAdapter" (wt.properties) value is same as the ldap used in Windchill after the rehosting. If the value is not changed modify it using the xconfmanager utility and try the upgrade again. It worked for me.
Aug 17, 2017 2:27 PM UTC
I have the same issue.
On the original and rehosted systems, the value set for  "wt.federation.org.defaultAdapter" is the same.
If they should be different, what should they be?
The values is com.usec.LDAP on both.
Aug 21, 2017 7:07 AM UTC
Did you change the hostname while rehosting?
That error is applicable when the host name is changed.
