Jul 24, 2017 2:50 PM UTC
Upgrade from Ooracle 11g to 12c
I am working on an upgrade from Windchill10.0 mo40 running on Oracle 11g
I would like to upgrade to Windchill 11.0 m030 running on Oracle 12c.
Do I need to do anyjthing special to do this or will the Upgrade Manager handle all of the updates to Windchill and the Oracle schema?
Jul 24, 2017 7:45 PM UTC
WinDU tasks for 10.2 is enough.
I upgraded system from 10.1 to 11.0 there the WinDU tasks also only for 10.2.
You must use export/import dump procedurу for oracle.
Jul 24, 2017 3:25 PM UTC
You need to run WinDU tasks for Upgrade preparation.
Export/import oracle database to dump file.
BenLoosli23-Emerald IIIAuthor
Jul 24, 2017 3:34 PM UTC
That is a problem with the way PTC has mishandled WinDU!
I have run WinDU for the 10.2 upgrade, but PTC did not release WinDU patches for a 10.0 to 11.0 upgrade.
All of the Upgrade for 10.2 WinDU checks come back with no errors and a few warnings. A complete WinDU run does the same.
That is my plan for the database, export from the 11g and import to 12c, then run Upgrade Manager.
