Feb 16, 2015 9:07 AM UTC
Upgrade Issue when running upgrade manager. Standalone migrator fails
Hi All,
I'm in middle of upgrade from Windchill 10.1 M030 to 10.2 M020. Getting a issue while running upgrade manager in target
server in the Standalone migrator task.
Following is the error which I'm getting
Error occurred when executing the task of Populate the fields FullName, Last and Email in the WTUser table.
Error is
(com.ptc.windchill.upgrade.updates.directives.directivesResource/27) com.ptc.windchill.upgrade.updates.DirectiveExecutionException: Unexpected error executing a JavaMigratorDirective with className=wt.org.PopulateUserFullNameFields.
Nested exception is: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)Caused by:
  1. wt.util.WTException: Error in finding mapping key for "user.cn" in adapter : local.xxxx.EnterpriseLdap
Nested exception is: com.infoengine.exception.adapter.IEAdapterException; nested exception is:
  1. javax.naming.NameNotFoundException: [LDAP: error code 32 - The entry cn=Xxxxx xxx,ou=wma users,ou=sbusers,ou=users,ou=mybusiness,dc=xxxx,dc=local specified as the search base does not exist in the Directory Server]; remaining name 'cn=Xxxxx xxx,ou=wma users,ou=sbusers,ou=users,ou=mybusiness,dc=xxxx,dc=local'
at wt.org.UserFullNameFieldsHelper.readPrincipal(UserFullNameFieldsHelper.java:407)
at wt.org.UserFullNameFieldsHelper.processPersistedUsers(UserFullNameFieldsHelper.java:187)
at wt.org.UserFullNameFieldsHelper.populateUserFullNameFieldsAndUpdate(UserFullNameFieldsHelper.java:107)
at wt.org.PopulateUserFullNameFields.runMigration(PopulateUserFullNameFields.java:29)
... 24 more
Caused by: com.infoengine.exception.adapter.IEAdapterException; nested exception is:
  1. javax.naming.NameNotFoundException: [LDAP: error code 32 - The entry cn=Xxxxx xxx,ou=wma users,ou=sbsusers,ou=users,ou=mybusiness,dc=xxxx,dc=local specified as the search base does not exist in the Directory Server]; remaining name 'cn=Xxxxx xxx,ou=wma users,ou=sbsusers,ou=users,ou=mybusiness,dc=xxxx,dc=local'
at com.infoengine.jndi.JNDIAdapterImpl.processRequest(JNDIAdapterImpl.java:254)
at com.infoengine.procunit.adapter.Adapter.send(Adapter.java:198)
at com.infoengine.SAK.ObjectWebject.invoke(ObjectWebject.java:262)
at com.infoengine.compiledTasks.file.D$3a$5cPTC$2dWindchill$5cWindchill$5ctasks.wt.federation.queryprincipals$2exml.invoke(queryprincipals$2exml.java:100)
at com.infoengine.SAK.Task.invoke(Task.java:1806)
at com.infoengine.SAK.Task.invoke(Task.java:1714)
at wt.org.UserFullNameFieldsHelper.readPrincipal(UserFullNameFieldsHelper.java:359)
... 27 more
Caused by: javax.naming.NameNotFoundException: [LDAP: error code 32 - The entry cn=Xxxxx xxx,ou=wma users,ou=sbsusers,ou=users,ou=mybusiness,dc=xxxx,dc=local specified as the search base does not exist in the Directory Server]; remaining name 'cn=Xxxxx xxx,ou=wma users,ou=sbsusers,ou=users,ou=mybusiness,dc=xxxx,dc=local'
I found a similar issue in ptc knowledgebase at document CS59225 and also tried those solutions. But this exception is coming for every user. Already I have disable
three users so far. That document is talking about disconnected users in ldap. I got that issue while running my WinDU but later I fixed that and
completed my WinDU task without any failed tasks or problems.
Source system is using Active directory server. Will that be a root cause of this issue.? How should I proceed now. Please advice
Feb 16, 2015 9:26 PM UTC
Has the target server been configured for Active Directory? The error message is saying that the search base configured for your EnterpriseLdap adapter doesn't exist in the Directory Server. Make sure this adapter is properly configured for Active Directory.
VINO12-AmethystAuthor
Feb 19, 2015 1:01 PM UTC
Thanks for your reply. And yes that was the issue then I've fixed that by properly configuring the Active Directory
in the target server.
Feb 20, 2015 3:03 PM UTC
Hey Vino,
How did you configure the Active Directory on the target? I thought that the upgrade manager did this automatically during the upgrade? Can you explain? I too am in the middle of an upgrade testing from 10.1 M020 to 10.2 M010.
Buddy
