Jun 14, 2016 2:28 PM UTC
Upgrading from Creo 2 to 3 should I delete the .wf folder?
Just that.
We're upgrading right now and I need to know if we'll need a script to delete the .wf folder from all user workstations.
Jun 14, 2016 3:18 PM UTC
That should be safe to leave alone when doing a Creo version upgrade since it is the local Windchill cache and Creo files are upward compatible.
When upgrading Windchill versions, then I have my users check-in all files, delete all workspaces and remove the cache folders from their hard drives.
Jun 14, 2016 3:23 PM UTC
We're doing both. I did launch once with a local Creo Parametric install and didn't see any errors but I want to test again with the network install all users will be on. Of course, I can't even get Creo 3.0 working due to the Creo Agent issue (CS180521) on a network install. Can't even find the executable yet and can't get the .msi to create it anywhere.
TomU
Jun 14, 2016 3:59 PM UTC
Don Senchuk‌, take a look at this discussion here: Creo 3 Network Install & Creo Platform Agent
