Apr 24, 2017 3:32 PM UTC
Upload failure starting "Upload Failure code: J03_WCCLD_CONNECTION_FAILURE"
Upload failure starting "Upload Failure code: J03_WCCLD_CONNECTION_FAILURE locMsg:Connection failed Applies To:....."  Submitted on e-support, and result was an SPR to improve error messaging.  How do we interpret this in the meantime?
Apr 26, 2017 3:08 PM UTC
Chrystal,
Can you provide a bit more information as to what actions you were performing when you received this error?  Were you creating a WTDocument or an  EPMDocument?
Jun 20, 2024 3:01 PM UTC
Hi, I was uploading a .obj file and it appered a similar error message.
How can I fix this problem?
Michele Barile
Jun 4, 2018 1:24 PM UTC
Did you ever find a solution for this, I'm receiving a similar message?
Sep 16, 2020 9:06 AM UTC
I'm having the same issue.
As far as I know this failure appears depending on your connection upload speed.
Did you find any way to solve this?
Thank you
Lluís
