Upload file in a WindChill document - OData REST API
I want to upload a file in WindChill. They give to us an REST API with the services to do this. They split an upload of file in 3 stages.
  • Stage 1 - We call a service where we give the number of files to upload. In this case only one.
  • Stage 2 - A multipart/formdata where we give the file to upload.
  • Stage 3 - The last stage where we give the file name, the file size etc...
I think my problem is on stage 2. All the stages run successfully but when i try to open the uploaded file, in this case a pdf, the file is blank, but with the same number of pages of the original one. I compare the content of the uploaded file with the original one and the content inside is the same with a big difference. The original is with an ANSI encoding while the uploaded one is with the UTF-8 encoding. So, I think my problem is on the stage 2.
I'm with some doubts on this stage. In C# I get the bytes[] of file, but in the end I need to pass this bytes to a string to send in a multipart form. What is the encoding that i should use to get string? I tested with default, UTF-8, UNICODE, ASCII encoding but nothing. Here is the example of the Post request body. In a C# I use the HTTPWebRequest to make a request.
------boundary
Content-Disposition: form-data; name="Master_URL"
https://MyUrl/Windchill/servlet/WindchillGW
------boundary
Content-Disposition: form-data; name="CacheDescriptor_array"
844032:844032:844032;
------boundary
Content-Disposition: form-data; name="844032"; filename="newDoc.pdf"
Content-Type: application/pdf
%PDF-1.7 //// The content of the file starts here
%µµµµ
1 0 obj
------boundary--
Before this approach I tried to convert the bytes[] ToBase64String and send an body like this:
------boundary
------boundary
844033:844033:844033;
------boundary
Content-Disposition: form-data; name="844033"; filename="newDoc.pdf"
Content-Transfer-Encoding: base64
JVBERi0xLjcNCiW1tbW1DQox ........ //// The content of the file starts here
------boundary--
In this case, when I try to open the file i get the error "Failed to load PDF document". The file is corrupt.
I think the problem is on the stage 2, but I will share the body that i send in last stage for your understanding.
{"ContentInfo":[{"StreamId":844034,"EncodedInfo": "844034%3A40384%3A9276564%3A844034","FileName": "newDoc.pdf","PrimaryContent": true,"MimeType" : "application/pdf","FileSize" : 40384}]}
The StreamId and the EncodedInfo are returns of the stage 2 that I need to provide in the stage 3.
Anyone can see what I'm doing wrong? Anyone have some tips to help me to solve this issue?
Many thanks.
Hello Marco,
There is exists one interesting fact, that order of entities in form-data is important!
From java doc
 * <br>For regular upload, client needs to send the data in following format and order:
 * <br>-----------------------------boundary
 * <br>Content-Disposition: form-data; name="Master_URL"
 * <br>&lt;Master WindchillGW URL&gt;
 * <br>Content-Disposition: form-data; name="CacheDescriptor_array"
 * <br>&lt;streamid&gt;:&lt;filename&gt;:&lt;contentid&gt;:&lt;filesize&gt;;&lt;streamid&gt;:&lt;filename&gt;:&lt;contentid&gt;:&lt;filesize&gt;;...
 * <br>Content-Disposition: form-data; name="streamContentFromURL"
 * <br>&lt;file download URL&gt;
 * <br>Content-Disposition: form-data; name="&lt;filename&gt;"; filename="&lt;filepath&gt;"
 * <br>&lt;actual content file&gt;
 * <br>...
 * <br>
 * <br>For multi-chapter upload, client needs to send the data in following format:
 * <br>Content-Disposition: form-data; name="ChapteredCacheDescriptor_array"
 * <br>Content-Disposition: form-data; name="chaptered-upload-info"
 * <br>upload-chapters-count=&lt;Number of chapters to upload&gt;
 * <br>delegate=&lt;Delegate Name&gt; <nbsp/><nbsp/><nbsp/><nbsp/> (Optional)
 * <br>prev-content-data=&lt;Previous content data&gt; <nbsp/><nbsp/><nbsp/><nbsp/> (Required if you need to copy chapters)
 * <br>copyChapters=&lt;chaptername&gt;:&lt;chapter filesize&gt;:&lt;checksum&gt;
 * <br>...
 * <br>Content-Disposition: form-data; name="Chapter";
 * <br>x-ptc-chapter-name:&lt;Chapter Name&gt;
 * <br>x-ptc-chapter-size:&lt;Chapter Size&gt;
 * <br>x-ptc-chapter-checksum:&lt;Check sum&gt; <nbsp/><nbsp/><nbsp/><nbsp/>(optional pass 0 if no value is available)
 * <br>x-ptc-stream-id:&lt;Stream Id&gt;
Did you have finally solve your issue?
I try also to use those api rest to upload documents, but I struggle with PDF files.
It's working perfectly in case of simple ascii files, but I c'ant upload a pdf file: at the end, the file uploaded in windchill is corrupted.
I don't know how to create the body of the stage 2 for pdf or other binary files.
Thank you very much for your feedback
Thierry
Could you post the MethodServer log exception?
No, I'm not admin of the system so I've no acces on the Methodserver.
In fact, when I use the stage 2, I've no error message: at the end, I'm able to do stage 1, 2 and 3, the content of the WTDocument is created but in case of PDF, the file created in windchill is corrupted when I try to open it.
When I do that for a simple ascii file, it's working perfectly: file is created in Windchill and I can open it.
My issue is how created the body for the stage2 to be able to upload a pdf, and especially, the third part like this one:
------boundary
%µµµµ
1 0 obj
------boundary--
Thank you for your help
