avillanueva
23-Emerald II
Sep 25, 2025 11:30 AM UTC
There can be many. I searched for that in the knowledge base and many articles came back. Some point to upload sizes, vpn issues, local cache
https://www.ptc.com/en/support/article/CS443107?source=search
https://www.ptc.com/en/support/article/CS378267?source=search
https://www.ptc.com/en/support/article/CS383037?source=search
https://www.ptc.com/en/support/article/CS322959?source=search
https://www.ptc.com/en/support/article/CS437608?source=search
There are more but please provide more that your version. Does it repeat? Is it a large file? All users? Intermittent?
avillanueva
23-Emerald II
Rado4-ParticipantAuthor
Sep 25, 2025 11:56 AM UTC
Hi Avillanueva,
what I did is, borrowed a Creo license, disconnected from VPN, and this actually worked, not sure why would VPN cause an issue, never happened before, clearing the cache didn't help, the file size if fairly large, but yes  bottom line, it was the VPN.
thank you so much for researching this, I will keep it for our records.
