May 25, 2016 8:22 AM UTC
Urgently Need Help on FRACAS Data Migration
A single Report in Windchill FRACAS may have multiple attachments. Attachments are stored on the Windchill Quality Solutions Server in the attachments folder in the installation directory. If the defaults were selected during installation, the path is C:\Program Files\PTC\WindchillQuality Solutions 10.1\Windchill Quality Solutions\Attachments. The files stored in this
folder are assigned randomly generated names when they are uploaded.
We are migrating FRACAS Data from a legacy system to Windchill and facing the problem on how to map old/historical files in Windchill FRACAS. Our old files are named with Incident Number which are available in Windchill FRACAS too. So for Example: If we have an Incident number as ANQTP and if it has 2 Attachments, then Attachments are named as "ANQTP_1.xls" and "ANQTP_2.pptx".
Please suggest how we can do this mapping . Appreciate your quick answer on it. This is urgent.
May 25, 2016 3:25 PM UTC
Dear Rajib
Before I suggest something, could you please advise how are you migrating the data ? I mean what tool/framework are you using  ?
Regards
Mahesh Gupta
May 25, 2016 3:53 PM UTC
Hi Mahesh,
Our Legacy FRACAS system is running on Oracle 8 and files were attached in BLOB format. Initially we thought we could convert those back to files and then in  Windchill FRACAS we can just place those files in File Server after updating the File Path for each incident. Our thought process was found completely wrong when we did deep analysis on how Files are stored in Windchill Fracas. We found the path where files (attachments) are getting saved in Windchill FRACAS and that is C:\Program Files\PTC\WindchillQuality Solutions 10.1\Windchill Quality Solutions\Attachments. But files/attachments are stored in CLOB or some binary format. We can access the DB through SQL Developer and can see the Attachment table. We are very new to Windchill and that's why we had no clue at the initial.
We are not using any tool or framework , actually we don't know if any tool is there in Windchill which can help on this.
Now what we are planning is to get access to the Legacy system's DB  and from backend if we can do anything.
if you can share / suggest anything would be great help!  We have already migrated all Incident Records with other data in Windchill FRACAS. Only thing pending is to attach those old Attachments with their respective Incident Number.
Rajib
May 25, 2016 5:53 PM UTC
Dear Rajib
If I understand correctly, here is what you need to do. If my understanding is not correct, please share more details so that I can point you the right steps.
  1. Extract/Export all your legacy data from Oracle 8 and have it downloaded to some common location. You may to talk to your DBA/developers to do this.
  2. WQS has a capability to import the data from system. Use Template functionality where you can define the mapping and use the same template for all your data load.
  3. You also have an option to schedule an import job in WQS which would read all your data to load on WQS.
Let me know how it goes..
Regards
Mahesh Gupta
