Jan 7, 2024 5:54 PM UTC
Use case for Independent Expression in a system
We have a system that has so far used Assigned Expression, we are exploring the functionality of Independent Expressions and can we make use of the same. As I understand, once the system is made ready for Independent Exp, all defined expression will also be converted into Independent Exp. I wanted to understand the impact of doing it and when should we think about doing the conversion.
TIA.
HS
avillanueva
23-Emerald II
Jan 8, 2024 12:56 PM UTC
Just so those on board know, this is related to options and variants.
https://support.ptc.com/help/wnc/r12.0.2.0/en/#page/Windchill_Help_Center%2FOptionsConversionUtility.html
