Nov 24, 2014 5:08 AM UTC
User Control Access
Hi!
Can somebody teach me where/how to configure to control the access of each user?
For example:
User1- can open and print the document.
User2- can open,modify and save the document.
User3- can open, modify, save and print document.
Thanks in advac.
Luar
Nov 25, 2014 1:10 AM UTC
Recommend in Windchill you create ACLs by Role or Group, not by User.
If you have multiple organizations in your Windchill system, suggest you create ACL at the organization level. Do you want the ACL to be available within every Product or Library Container in the Org? If yes, create the ACL in the /Default (your org)/PDM domain. If No, then you want to create ACL in the Product or Library Containers.
1) Log into WC as org admin
2) Open "Browse" tab
3) Click on Organization Icon and select "Utilities"
4) Select "Policy Administrator",authenticate to the pop up window.
5) Click + sign to expand Default (organization - your org), click on PDM (organization - your org), then click the "Update" Command Button.
6) In the "Administrative Domain" GUI, select "Access Control" tab, click "Create" command button to create your new ACL.
7) In the "Access Control Rule" GUI, click on "Help" and it will explain the rest of the steps for you.
Nov 24, 2014 5:27 AM UTC
You can create profiles on the site or org level. Check Windchill Help Center for further details on Profiles.
Luar1-VisitorAuthor
Nov 24, 2014 7:34 AM UTC
Hi malavika,
Thanks for the reply. can you show me how?
thanks!
