Users disappear from Participant Administration page
We started seeing a weird behavior with the Participant Administration table and I'm hoping someone knows the cause.
Users can be added to the Participant Administration table successfully, but they may or may not stay in the table after navigating away from the page. Most of the time they will just disappear. Sometimes after adding them several times, they might stay in the table. here is no discernable pattern to this.
This isn't a session-based issue as described in CS407556. It happens any time you come back to the Participant Administration table.
The system has not always done this, and no changes are associated with this behavior change.
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.14
