6-Contributor
Apr 30, 2013 5:53 PM UTC
Using Eclipse
Documentation 10_MR040_WindchillCustomizationGuide.pdf on page 51 it shows project cust_Windchill_src in Eclipse. In order to load that project in you must follow directions from ant -f bin/tools.xml eclipse_project.help I followed these directions. Step 1) Run the eclipse_project task is too vague. I can get the cust_Windchill_src folder into the project window of Eclipse, but I have no supporting libraries or src folders. Can anyone explain what "run the eclipse_project task" actually means? I put in Filesync, but I am not sure it is working. Thanks.
NitinAnswer
Apr 30, 2013 6:34 PM UTC
Step 1) Run the eclipse_project task.
this implies running the ant command as below -
C:\ptc\Windchill_10.0\Windchill>ant -f bin/tools.xml eclipse_project
It is basically creating a workspace and placing .classpath and .project filesin this workspace.
Further as the eclipse_project.help says, the newly created workspace and projects are used.
Hope this helps.
-Nitin
Nitin1-VisitorAnswer
Hope this helps.
-Nitin
dkessler6-ContributorAuthor
6-Contributor
Apr 30, 2013 7:11 PM UTC
Okay that makes sense. It worked, thanks.
Apr 24, 2017 5:37 AM UTC
Still I am not able to find the cust_Windchill_src can u please explain clearly about the issue, I run the command and is is working properly.
Sep 18, 2017 12:19 PM UTC
Hi  Reetakota,
Steps:
1. Install JRE/JDK and Eclipse.
2. Run the commands: ant -f bin/tools.xml eclipse_project.help
You will find the cust_Windchill_src folder in the  Eclipse Workspace Directory.
If you go with by default options, it will be created under the <Windchill>\eclipse\cust_Windchill_src folder
Attached is a snapshot, FYI.
Venkat
B-WI
Nov 24, 2017 3:03 PM UTC
It is the second Ant call that is crucial. That line is not present on page 56 of the current 11_F000 version of the guide.
Feb 12, 2020 6:20 AM UTC
Hello, there is a video of training for example from the documentation
https://www.youtube.com/watch?v=-14BSAwteVw&list=PLjm4gmbLQwoeqQSP7xUhCnInGknqTBAZV&index=2
