Jun 16, 2016 3:55 AM UTC
Using Infoengine for retrieving workflow task information
I am curious if someone has done this. It does not look like it is straight forward using infoengine. So wondering, if anyone has used infoengine to get workflow intruction, variables, and voting options of an open task.
thanks.
satre-2Answer
Jun 16, 2016 12:55 PM UTC
I don’t know your exact requirement to use info engine to get workflow activity information.
I had similar requiring for one cognos report, where I have to use info engine to get workflow related information using info Engine.  It’s tedious to write webjects to retrieve all workflow related information when you have API’s easily available. I wrote one helper class to retrieve all require information using API. Call helper class from task/xml file, which with return result in infoengine group.
So you can use the xml/task for cognos reports, web service or for any other purpose.
Below is example
<ie:webject name="Create-Group" type="GRP">
    <ie:param name="GROUP_OUT" data="out"/>
</ie:webject>
System.out.println("***************IN TASK ********************");
Group out = getGroup( "out" );
String oID=getParam("objectID").toString();
Group group=ext.report.SummaryReport.getDescription(oID);
Element[] elements = group.getElementArray();
for (int i = 0; i < elements.length; i++) {
    Element e= (Element) elements[i];
    out.addElement ( e );
System.out.println("*************** out summary Header********************");
<ie:webject name="Return-Groups" type="GRP">
<ie:param name="GROUP_IN" data="out"/>
</ie:webject>
public static Group getRoutingHistory(String objectID) {
  System.out.println("WithoutRepeter");
  Group grp = new Group();
  try {
  ReferenceFactory rf = new ReferenceFactory();
  WTReference ref = rf.getReference(objectID);
  WTChangeRequest2 wtChangeRequest2 = (WTChangeRequest2) ref.getObject();
  Enumeration processes = WfEngineHelper.service.getAssociatedProcesses(wtChangeRequest2, null);
  while (processes.hasMoreElements()) {
  WfProcess process = (WfProcess) processes.nextElement();
  NmOid nmOid = new NmOid(process);
  QueryResult status = WorkflowCommands.getRouteStatus(nmOid);
  while (status.hasMoreElements()) {
  Object obj = status.nextElement();
  String activityName = "N/A";
  String assigne = "N/A";
  String role = "N/A";
  String comments = "N/A";
  String vote = "N/A";
  String actStatus = "N/A";
  String completed = "N/A";
  String start = "N/A";
  String signature = "N/A";
  String completedBy = "N/A";
  if (obj.getClass().isAssignableFrom(WorkItem.class)) {
  WorkItem workitem = (WorkItem) obj;
  activityName = ((WfAssignedActivity) workitem.getSource().getObject()).getName();
  assigne = workitem.getOwnership().getOwner().getFullName();
  role = workitem.getRole().getDisplay();
  if (workitem.getStatus().toString().equalsIgnoreCase(WfAssignmentState.COMPLETED.toString())) {
  actStatus = new URLFactory().getHREF("/netmarkets/images/checked.gif");
  } else {
  actStatus = new URLFactory().getHREF("/netmarkets/images/unchecked.gif");
  WfVotingEventAudit wfVotingEventAudit = getAuditEvent(workitem);
  if (wfVotingEventAudit != null) {
  comments = wfVotingEventAudit.getUserComment();
  vote = wfVotingEventAudit.getEventList().toString();
  DateFormat dateFormat = new SimpleDateFormat("dd-MMM-yyy");
  completed = ((wfVotingEventAudit.getTimestamp()) == null) ? "" : dateFormat.format(wfVotingEventAudit.getTimestamp());
  start = ((wfVotingEventAudit.getCreateTimestamp()) == null) ? "" : dateFormat.format(wfVotingEventAudit.getCreateTimestamp());
  signature = getSignature((WTUser) wfVotingEventAudit.getUserRef().getObject());
  completedBy = wfVotingEventAudit.getUserRef().getFullName();
  } else if (obj.getClass().isAssignableFrom(Element.class)) {
  continue;
  } else if (obj.getClass().isAssignableFrom(WfVotingEventAudit.class)) {
  WfVotingEventAudit wfVotingEventAudit = (WfVotingEventAudit) obj;
  activityName = wfVotingEventAudit.getActivityName();
  assigne = wfVotingEventAudit.getAssigneeRef().getFullName();
  role = ((wfVotingEventAudit.getRole() == null) ? "" : wfVotingEventAudit.getRole().getDisplay());
  completed = ((wfVotingEventAudit.getTimestamp()) == null) ? "N/A" : dateFormat.format(wfVotingEventAudit.getTimestamp());
  start = ((wfVotingEventAudit.getCreateTimestamp()) == null) ? "N/A" : dateFormat.format(wfVotingEventAudit.getCreateTimestamp());
  Element element = new Element();
  element.addAtt(new Att("Assigne", assigne));
  element.addAtt(new Att("Role", role));
  comments = ((comments.trim().length() == 0 ? "N/A" : comments));
  System.out.println("Comments-->" + comments);
  element.addAtt(new Att("Comments", comments));
  vote = vote.replace("[", "");
  vote = vote.replace("]", "");
  vote = ((vote.length() == 0 ? "N/A" : vote));
  if (!completed.equalsIgnoreCase("N/A")){
  vote = "Task Completed";
  element.addAtt(new Att("vote", vote));
  element.addAtt(new Att("Status", actStatus));
  element.addAtt(new Att("Completed", completed.replace("-", "")));
  element.addAtt(new Att("start", start.replace("-", "")));
  element.addAtt(new Att("WorkItemName", activityName));
  element.addAtt(new Att("Signature", signature));
  element.addAtt(new Att("completedBy", completedBy));
  System.out.println("Completed by " + completedBy);
  // System.out.println("adding element "+element);
  grp.addElement(element);
  } catch (WTException e) {
  e.printStackTrace();
  } catch (WTRuntimeException e) {
  // TODO Auto-generated catch block
  } catch (PropertyVetoException e) {
  } catch (IOException e) {
  return grp;
Hope it helps !!!
Shreyas
satre-21-VisitorAnswer
Below is example
</ie:webject>
</ie:webject>
  try {
  } else {
  continue;
  return grp;
Hope it helps !!!
Shreyas
Jun 16, 2016 5:03 PM UTC
Thanks Shreyas for your quick response. I dig into it.
