Oct 13, 2023 4:53 AM UTC
Using ODATA REST APIs how to get representations of all versions of CAD Document?
Hi All,
Consider I have CAD document ABC--> 3.5, ABC--> 2.4 and ABC-->1.1
I need to fetch all three versions of CAD document along with representations for every version. I am using
/CADDocumens rest API and I am expanding "AllOlderVersion" service .
for ex:
expand: AllOlderVersion($select=AuthoringApplication,ID,VersionID,Name,Number,State,Version,Category,TypeIcon),Representations($filter=DefaultRepresentation eq true;$select=ID,CreoViewURL).
If I do this, I am getting representation only for the latest version. But I need representations for all the versions. How Can i achieve this ?
Emeritus
Oct 20, 2023 6:45 AM UTC
Hi gmydoor-2,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Vivek N
gmydoor-210-MarbleAuthor
Oct 20, 2023 6:50 AM UTC
Hi @vnamboodheri .. AllOlderVersion endpoint is the customized one. I have got another solution for my issue. We can use Revisions end point instead of AllOlderVersion to get representations of all versions of CAD documents.
