May 19, 2015 8:53 AM UTC
Using Query Builder, is there any way to limit results to the current context?
I know that I can limit queries to a specific context by explicitly naming it as a constraint in the criteria tab (either with name or identifier). But this requires that I manually edit the report for each separate context. Is there some way that I could constrain it to only give results from the context in which the report is run? I would like to have one report defined at site level which would give different results for each context.
23-Emerald II
May 21, 2015 10:34 PM UTC
What if you made the Criteria for the Context as a parameter that could then be filled in at runtime rather than specifying the context criteria as a constant?
