Jul 10, 2023 2:53 PM UTC
Vault data issue
I am using Windchill Supplier Management Release 12.0 and Datecode with CPS 12.0.0.0
Could you please share with us the steps for copying the latest iteration of vault data?
HelesicPetr
Jul 11, 2023 6:28 AM UTC
Hello @CG_10468982
What is your issue?
You can go to a database find the latest version of your object and find information about vault.
and then just copy the file from a folder.
select for EPMDocument to get vault information in MS SQL
select substring(convert(varchar(100),convert(varbinary(100), FVI.uniqueSequenceNumber, 256),2),3,14) vaultFileName,apData.idA3A5 as FvItem, apData.fileName ,MSTR.documentNumber, EPM.versionIdA2versionInfo,EPM.iterationIdA2iterationInfo, MSTR.CADName from wcuser.EPMDocument EPM
INNER JOIN wcuser.HolderToContent CONTENT
 ON CONTENT.idA3A5 = EPM.idA2A2
 inner join wcuser.ApplicationData apData
 ON apData.idA2A2 = CONTENT.idA3B5
 inner join wcuser.EPMDocumentMaster MSTR
 on MSTR.idA2A2 = EPM.idA3masterReference
 inner join wcuser.FvItem FVI
 on apData.idA3A5 = FVI.idA2A2
 where MSTR.CADName like 'ASSEMBLY123.asm' and EPM.latestiterationInfo=1
then just use CTRL+C , CTRL+V in the correct folder
Hope this can help
PS> for family table there is little bit different select
PetrH
