Jan 31, 2024 8:52 AM UTC
Vaults on Windchill 12.1.2.4 (cluster env) are becoming invalid randomly.
defaultsystemvalut and defaultuploadvault mounts are becoming invalid randomly on Windchill 12.1.2.4.
When the mount is validated, it says some of the mounts are not valid. When tried to validate each object, they becomes valid. But again after sometime, they are becoming invalid. Can someone help?
MarcoTosin
Jan 31, 2024 8:56 AM UTC
Take a look at this HUB article
[Knowledge Hub] Windchill PLM - Troubleshooting Mount Validation Issues
Marco
MarcoTosin
Jan 31, 2024 8:58 AM UTC
There is also specific article on cluster environment
 On a cluster environment Vaults mounts become INVALID randomly in Windchill PDMLink 12
Marco
Srivalli12-AmethystAuthor
Jan 31, 2024 9:26 AM UTC
@Marco_Tosin  Thanks for the information. This is on our Production environment, we cannot try this because we are unsure if it creates any performance issues.
Rocket_Max
Jan 31, 2024 9:31 AM UTC
  1. Priode wt.properties file
  2. cluster?
  3. Priode log?
  4. Is communication normal?
  5. Is the disk full?
Jan 31, 2024 10:06 AM UTC
It's a cluster environment. Disk is not full. The article shows to update wt.properties which may cause performance issues.
