Dec 13, 2025 12:09 PM UTC
virtual machine migration, However, it seems that data visibility is no longer ensured
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.0
Hello, following a virtual machine migration, we have restarted the database and the application server. However, it seems that data visibility through the graphical interface is no longer ensured. We need assistance to understand the cause, if possible, before Monday, December 15, at 8:00 AM.
Here are the errors that I faced
Java.net.SocketException: Software caused connection abort: socket write error at java.rmi/sun. rm. server.UnicastRef. invoke(UnicastRef. java: 160) at wt. cache. CacheManager_Stub. removeEntries (Unknown Source) at wt. cache. SLaveCache.notifySLaveServer(SLaveCache. java: 253) at wt. cache. SLaveCache.notifySLaveServerBatch(SLaveCache. java: 234) at wt. cache. SLaveCache.processNotifications(SlaveCache. java: 212) at wt. cache. SLaveCache. processNotificationQueue(SlaveCache. java: 125) at java. base/java. Lang. Thread. run(Thread. java:829) Caused by: java.net.SocketException: Software caused connection abort: socket write error
    Dec 18, 2025 8:52 AM UTC
    Can Windchill Methodserver be started successfully after the virtual machine migration?
