Mar 19, 2026 9:26 AM UTC
Visualization Configuration Administration - Org Level
Hi Guys,
I successfully created a rule using a watermark .ini file and added it at the site level. I tried adding it at the org level, but it’s not showing up.
However, I don’t know how to apply it at the organization level.
Aj
Mar 19, 2026 9:43 AM UTC
@Fadel Thanks for the response,
I successfully applied it at the site level without any issues, but when I use the same setup at the organization level, it doesn’t work.
Aj
Fadel
23-Emerald II
Mar 19, 2026 9:45 AM UTC
Raise a Technical support call to have a colleague from the VIZ team assist you .
Buiꓘa
