Jun 7, 2017 4:52 PM UTC
Want to copy a WTPart structure and only inlcude specific WTParts in the new structure
We want to create an overloaded master BOM for our top-level machines and then have the user make a copy of the master BOM and only include the specific WTParts needed to create the new machine structure.
Overloaded BOM WTPart example for windchill
lvl0 5-BAR820-MASTER-BOM
lvl1 5-G13071 (group of different steel frames to select from)
lvl2  5-27926
lvl2  5-26113
lvl2  5-21341
lvl2  5-10893
lvl1 5-G13076 (group of different control panels to select)
lvl2  5-27808
lvl2  5-27807
In the example above, I want my user to copy the 5-BAR820-MASTER-BOM and give it a new name (for example, 5-BAR820-SN1000) and then either include or exclude the LVL1 and LVL2 WTParts as needed to create the new machine.   I rename the top-level to 5-BAR820-SN1000 and then  select the existing WTParts to include and I have a new WTPart structure as shown below.
lvl0 5-BAR820-SN1000
lvl2  5-26113
lvl2  5-27807
I have tried the 'save as' but when I show the dependents in the 'save as' window, I am asked for new names for each WTPart in the structure.   The only name that is changing is the top-level WTPart.
Anyone with recommendations how this can be done?   Best practices?  The steps that I should be taking to make this work?
Thanks for any insights.
Mike Schumacher
Jun 7, 2017 7:04 PM UTC
Use OOTB Options and Variant module to create your variant BOMs.  Once setup (takes some work) you'll have a robust  system for creating variants of a machine....as a PLUS the user that is creating the variant will only have to answer some simple questions to get a complicated BOM.
Jun 7, 2017 7:07 PM UTC
Mike - there are two possibilities
1 - Re-identify the intermediate assemblies as the definition is varying.  You can not reuse the same part number but say it is different in this case.  eg lvl1 5-G13071 & lvl1 5-G13076 become lvl1 5-G13071_sn1000 & lvl1 5-G13076_sn1000
2 - Use a configurable methodology (options and variants).  In this case the top and intermediate nodes would be configurable and you would be creating lvl0 5-BAR820-SN1000 as a variant based upon selecting the appropriate selected modules under lvl1 5-G13071 & lvl1 5-G13076 .  You can find more information on this here:  https://support.ptc.com/cs/help/windchill_hc/wc110_hc/index.jspx?id=OptionsManagProdConfigOview&action=show‌.  The powersystem demo dataset is an example you could kick the tires on.
