Jun 26, 2024 5:08 PM UTC
want to know about string type of attributes limitations and default string length and constraints.
Version: Windchill 12.1
Use Case: Created Reusable and global attribute and i used those in Manage types like WT Part, those attribute when i add and edit, i see the default constraint added and it was showing lock on first column. and it says modeled attribute. simply, i want to know about that modeled constraint and how it works and how it added. what is the limitation and advantage.
Description:
Hello Community,
I wanted to know about the Attributes which is type of string. that i want to know about default constraints windchill provide OOTB.
String length is maximum upto 2000.
what are modeled constraints how it gets added in attribute in type and attribute.
relevant documents or help or knowledgebase URLs would be help.
HelesicPetr
Jun 27, 2024 6:12 AM UTC
Hi @AS_11081239
I don't understand the question
The answer is in the document that you've provided
btw the knowledge base and help can help you 😄
CS220838 - What is the maximum length for modeled attributes of type String in Windchill PLM
Customizing Column Lengths
CS420044 - How to increase Character Length of Number attribute
PetrH
HelesicPetr
Hi @AS_11081239
PetrH
