Jan 24, 2023 4:22 AM UTC
Want to know can we create or configure it on EPM Documents.
I am using Windchill PartsLink Release 11.1 and Datecode with CPS M010-CPS02
Can we create or configure parts classification on EPM documents?
    HelesicPetr
    Jan 24, 2023 6:23 AM UTC
    Hi @JM_10268583
    Only WTParts supports the classification in the PartsLink
    PetrH
    avillanueva
    23-Emerald II
    Jan 24, 2023 2:33 PM UTC
    And WC12 supports WTDocuments but not EPMDocuments. I would suggest using WTParts and their linkage as a stand in for classify the epmdocument.
    Jan 24, 2023 2:55 PM UTC
    Hello @JM_10268583,
    @HelesicPetr is right, only WTParts or WTDocuments can be classified, not EPMDocuments.  Classification search work with WTParts or with WTDocuments.
    But you can map WTPart classification attributes with Creo parameters. In that way you have an automatic synchronization in both directions. Implicit mapping is required, i mean exact same name for each attribute and parameter. Check this video from 4CAD:
    BR,
    Pascal
    Jan 24, 2023 3:33 PM UTC
    I made my video public but still in "Awaiting Approval". I don't know what that means.
    HelesicPetr
    Jan 26, 2023 7:50 AM UTC
    Hi @Pascal_Brunet
    It means that someone who is responsible has to approve if the video is OK.
    PetrH
