want to move the data from one context to another context through Customization.
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS20
We would like to move the Data from Existing Container to the new Container through customization.
Please suggest your thoughts on this.
We have move API for that. Below link will be helpful to develop a utility.
All the versions and iterations will be moved to new context.
https://www.ptc.com/en/support/article/CS69568
Regards
Ajit
Hello Ajit,
Thank you for your reply. We will be able to move the data by using this API but in my case there are 1 lakh+ objects which has to move and its taking so long to move the objects (1000 objects in a day).
Would like to know if any other code or any other method to move the data faster. It helps if we have any other method to proceed.
Thank you !
Thanks for your reply. I think you need to fine-tune the utility. The whole 1 lakh+ should not take a day.
I may be able to help you to fine-tune it if you would like.
Regards
Ajit
How often do you need to move files between contexts?
Is it really worth a custom app if it is a few times when it can be done manually very easily.
We would like to move the bulk amount of Data (1 lakh+).
Thank you!
When you move data it can retain the access permissions from the old context. There is an action "Reset Teams" that you might need to do so the permissions are correct.
