Oct 13, 2025 11:40 AM UTC
WARNING: Table size limit reached If your object is not in the table, either narrow your search crit
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS11
while attaching BOM to Process Plan, we are getting GC overhead limit exceeded in windchill PDM Link
Here are the errors that I faced
If your object is not in the table, either narrow your search criteria, use the View drop-down to apply a filter, or click N
    Catalina
    Community Manager
    Oct 13, 2025 12:28 PM UTC
    Hi @RM_10622208
    Thank you for your question!
    I’d like to recommend to bring more details and context to your initial inquiry. For example:
    • Does the error occur consistently with the same BOM or across multiple BOMs?
    • Are there any filters or view settings applied that could reduce the table size?
    • Have you reviewed the method server logs for memory-related warnings or stack traces?
    Please add screenshot(s) to better understand what you are trying to do in your process.
    Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
    Here's what a good question for Windchill looks like.
    Thank you for your participation and please let me know if you need further assistance!
    Best regards,
    Catalina | PTC Community Manager
    joe_morton
    Oct 13, 2025 2:59 PM UTC
    You can consider changing the preference for your site: https://www.ptc.com/en/support/article/CS35143?source=search
    The Table Size Limit is there to help avoid poor system performance. As long as you test and make sure that your system can handle it, it should be ok to increase the limit.
