Oct 22, 2026 11:33 AM UTC
Watermarking on representation
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.26 We want to do watermarking with object state for every time .pdf representation generated through configuration if possible if not then customization also fine
18-Opal
Oct 22, 2026 12:00 PM UTC
Hi ​@SC_14664320,
There are multiple ways to implement this, depending on your requirement.
Do you want the state watermark to appear on the representation when it is opened in Creo View?
Oct 22, 2026 12:28 PM UTC
@TDT
I want to watermarking in server itself on generated .PDF so that everyone can see during download of it
TDT18-OpalAnswer
18-Opal
Oct 22, 2026 12:34 PM UTC
Nov 2, 2026 8:15 PM UTC
Hi  ​@SC_14664320 This can be achieved using custom code(AfterEDRLoader). We implemented the exact same need meaning that, the print of the lifecycle state should be done for non mature states...
Dobi
Nov 3, 2026 3:47 PM UTC
Like ​@TDT says, there are lots of ways to do this.
Depending on what version of CreoView adapters you have, there may be some out of the box options.
if you don’t want to go the CreoView, or WEX route there are also options with pdfbox to customize your own overlays. This works best in conjunction with the afterEDRLoader.
