Jan 30, 2015 7:06 PM UTC
WC10 Baseline Functionality
Does anyone know if you can relate one baseline to another? Has anyone customized that?
Also looking to find out if anyone knows how if a baseline can be set up or customized to allow for revising?
Jan 30, 2015 7:46 PM UTC
I'm not sure that this would be a good application for baselines. If you need this functionality for pre-production products, a pre-production release process (1X, 2X, 3X, etc) might provide more functionality, including revising, without any customization.
Jan 30, 2015 7:59 PM UTC
Thank you for your response Marvin!We are looking to use the baseline as a method for capturing a point in time review process (need the true version to version link the baseline provides). It will not be used for a relase process. We just need the ability to relate these reviews (baselines) to each other.
Jan 30, 2015 9:41 PM UTC
Would the relationship between the Baselines not be the Object (WTPart/Structure, CAD Document, Dynamic Document) being baselined? You can generate a (protected) Baseline and Name it "Review X". All of these Baselines would be visible from the object from which the baseline is initiated.
