May 22, 2025 10:14 AM UTC
WC11.2 is supported on 32 Bit systems ?
Version: Windchill 11.2
Use Case: Hello Experts, We have received one strange question - about WC 11.2 ... Do PTC support 32-bit systems specifically for Windchill? I saw on the Matrix but didn't find anything...I got some info about its supported-on Client OS (32 bit). but thought to check with experts here those might be using 32-bit server or client OS? Please Suggest.
Description:
check Use case
JimwangAnswer
May 26, 2025 8:53 AM UTC
In Windchill 11.2, Client OS can use 32bit refer to https://release-advisor.ptc.com/releaseMatrix?releaseId=170
For Server OS, it only support 64bit.
Fadel
23-Emerald II
May 22, 2025 12:13 PM UTC
starting 11.0 Windchill server code is supported only on 64-bit versions of the Windows Server operating system.
Buiꓘa
May 22, 2025 12:17 PM UTC
Any idea if any of your client using the client-side OS (32 bit)? I mean just thought to check....
Fadel
23-Emerald II
May 22, 2025 12:20 PM UTC
I can't disclose customer's info .
Not supported doesn't mean it won't  work , it may be fine but the hook is that you will not be able to get Technical support or R&D support .
Buiꓘa
Jimwang16-PearlAnswer
