Nov 13, 2025 6:39 PM UTC
wcadmin admin privilege remove
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.1.16
I accidentally remove wcadmin admin privilege and non on my Engineers are able to check - in their drawing into windchill
I'm not sure if these two issue are related,
Can you please get the admin privilege back to wcadmin account and take a look at the check-in issue
    Nov 13, 2025 7:02 PM UTC
    Are you using WindchillDS or another LDAP for your user authentication?
    Do you have a backup of your authorization files that could be restored to recover the settings?
    Do you have a DB administrator who can look in the DB and see what the permissions are for the wcadmin user and possibly reset them that way?
    Not sure why there is a connection between the wcadmin account and your user's ability to check-in work to Windchill.
    Nov 13, 2025 7:07 PM UTC
    I just accidently added wcadmin into View and print only group.
    Nov 13, 2025 8:35 PM UTC
    Try this.
    https://www.ptc.com/en/support/article/CS20793
    Temporarily disable permissions
    xconfmanager -s wt.access.enforce=false -t codebase/wt.properties -p
    Restart Windchill
    Login as wcadmin and remove wcadmin from ALL license groups.
    Reset the property
    xconfmanager --reset wt.access.enforce -p
    Restart Windchill
