May 23, 2016 9:58 AM UTC
WGM woes with Windchill External access
Hi all,
We have our internet gateway for all the access of several inhouse applications that can run on a browser.
Windchill is one of them. We use PDMLink 10.2
But the strange thing is that the login screen is not presented in WGM and DTI, because of the authentication requested by the internet gateway before the client can hit the windchill server.
Has anyone faced these kind of issues?
Best Regards
Hari
2-Explorer
May 24, 2016 1:37 AM UTC
Internet gateway works similar to Form based authentication - Follow the steps here  http://support.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=WCCG_BusLogicCust_DTIFrameworkFormBased&action=show for DTI
As for WGM, before you register or activate the session, open embedded browser and navigate to Windchill page. It will prompt for authentication, now go to server manager and register the server.
Regards
Binesh Kumar
Jan 26, 2017 1:06 PM UTC
Hi Kumar,
do you know a working solution when there is an additional authentication required such as netscaler before accessing the pdm server?
it's fine for workgroup manager client using the embedded browser for authentication.
I'm struggling @ DTI with netscaler authentication.
Do you have any idea on this topic?
thanks Gerhard
2-Explorer
Jan 26, 2017 1:16 PM UTC
Hi Gerhard,
Did you try this?
  1. Navigate to the following directory:<Windchill>\codebase\com\ptc\windchill\enterprise\nativeapp\msoi\client\xml
  2. Locate the following files:
    • wtDesktop.xml
    • wtOffice.xml
    • wtWindows.xml
  3. In each file, replace the following line:<action serverAction="DTILogin" type="HTTP"></action>with<action serverAction="DTILogin" type="WIZARD"></action>
Regards
Binesh
