Jul 12, 2023 4:45 PM UTC
What are the allowed values in $expand parameter in Structure_Get_Descendants?
I am using the Structure_Get_Descendants service from ptc-windchill-integration-connector thing and haven't found any documentation related to this parameter specifically.
So what can be used on this parameter and for what purposes?
Fadel
FadelAnswer
23-Emerald II
Aug 1, 2023 2:23 PM UTC
 Structure_Get_Descendants is a service under ptc-windchill-integration-connector
  • objectid: OR:<complate objec type name>:xxxx
    • For example:
      • Plant in Windchill MPMLink:OR:com.ptc.windchill.mpml.resource.MPMPlant:xxxx
      • Document in Windchill PDMLink: OR: wt.doc.WTDocument:xxxx
  • $select: Name, Number
    • The attributes which can be retrieved are defined in Type and Attribute Management
Buiꓘa
Fadel
Fadel23-Emerald IIAnswer
23-Emerald II
    • For example:
Buiꓘa
