What do you verify after applying a CPS on Windchill+? (Looking for real-world UAT examples)
Hi all,
We are running Windchill+ (SaaS) and have a CPS scheduled shortly. This will be one of our first updates, and we are trying to define a reasonable verification scope on our side.
We asked PTC about this. The guidance we received was essentially:
- There is no standard published checklist, and no customer examples were available to share.
- For Windchill+, system-level validation is performed by PTC; verification of customer-specific business processes is the customer's responsibility.
- A full UAT is not expected. The recommendation is a smoke test of representative day-to-day operations, for example: login, search, access to existing documents, document create/update/check-in, visualization (CAD viewables), file download, BOM/product structure navigation, and workflow approvals where used.
That makes sense as a principle, but we would like to hear how this plays out in practice. Specifically:
1. How deeply do you check each item?
Taking the list above as the baseline, how granular is your actual testing? For example, do you simply walk through one typical design workflow end to end (create a document, check it in, view it, download it, route it for approval) and call it done? Or do you cover each function in more detail - multiple object types, several document/part templates, different lifecycle states, different user roles and permissions, both Windchill UI and Creo/CAD client, and so on?
I would really appreciate a concrete picture of what "representative day-to-day operations" means in your environment. Have you also added items that are not on PTC's list based on past experience (e.g., customizations, ESI/ERP integration, CAD Worker, REST/OData consumers, single sign-on, email notifications, scheduled jobs, reports)?
2. Effort and timing
How long does it take, how many people are involved, and do you run the check in a pre-production/sandbox environment first, or only in production after the update?
3. What actually broke
This is the most useful part for us: have you hit regressions after a CPS, and if so, in which areas? Knowing where problems tend to appear would help us weight our checks rather than testing everything evenly.
Any checklist you are willing to share (even a sanitized one), or simply a description of your approach, would be very helpful.
Thanks in advance.
BryanKAnswer
Typically a CPS is not a problem. With it being windchill + it should be an easy task.
Items to check are typically related to what users do every day. Does not need to be exhaustive and would require only 1 or 2 people with different roles. 1-2 hours is probably enough time, if you are running OOTB Windchill
  1. log into WC (answers single signon and license profile allocation)
  2. create new object’s (cad, doc, wtpart) and check in. (answers vault, WGM compatibility, permissions)
  3. run your standard workflow/s (answers lifecycle, workflow, custom workflow code, if you have any)
  4. check to see if publishing works (answers visualizations)
  5. any customizations that you may have like listeners, integration's, interfaces etc.
You would need to know the before state so that you have something to compare to. Typically, the same tests.
BryanK17-PeridotAnswer
Thank you for the information and your quick response.
I now have a better understanding of how we should proceed with the CPS update checks.
I have one more question.
Do you perform the same level of testing in the production environment as in the integration environment?
Or do you test the integration environment thoroughly and perform only limited checks in the production environment?
Happy to help.
Typically more intensive testing on the dev environment, as that's where you can document fixes, workarounds and earmark production tests. Then just key tests on production.
