Jun 20, 2023 4:54 AM UTC
what is the difference between manual rehost and run rehost through utility
what is the difference between manual rehost and run rehost through utility ?  if it is can someone provide general steps for manual rehost ?
FYI :- i viewed rehost guide but i could not understand clearly
HelesicPetr
Jun 20, 2023 5:33 AM UTC
Hi @VR_10538993
difference is that
manual rehost you need to go throw all steps manually. You change all needed properties in all locations one by one.
The Rehost utility does almost all steps in one run. You just need to set up one configuration file.
Steps to rehost Windchill RENAME SCENERIO
1. Cloning LDAP Contents from Source LDAP to Target LDAP
2. Updating Host Names in Apache
3. Updating the Database on the Target System
4. Configuring Database Connection
5. Restart the Rehosted Windchill System
6. Updating Vaulting Configuration
7. Verify Site URL in Site Administration
PetrH
HelesicPetr
Hi @VR_10538993
difference is that
PetrH
Jun 20, 2023 5:48 AM UTC
HI @HelesicPetr
Thanks for the steps
so we will copy all the windchill, HTTPServer, Java these folders also from source and we can paste it in target system right ?
HelesicPetr
Jun 20, 2023 5:54 AM UTC
Hi @VR_10538993
Yes, you can just copy all data, files, folders from one system yo another.
The copy action should be done if Windchill, apache, DS, and database do not run.
PetrH
jbailey
18-Opal
Jun 20, 2023 4:50 PM UTC
So if you are using WC 12.0.2 and newer (where Windchill DS is gone) there is no more option to manually rehost as easy as it was in the past.
The rehost script has to be used because it makes changes to config files and the database.
Typically, you would have copied over the vaults / imported the db from the source in the target machine and just started Windchill (target was either duplicated from prod, or reconfigured prior to DB import).  We found this out the hard way during a DR test and had to use the script the hard time
Jun 20, 2023 5:08 PM UTC
Thanks @jbailey
