Mar 1, 2017 5:28 PM UTC
What is the error 'K03_UWGM_ACTION_NAME_MODIFYFORPRIVATE'
When a user tries to update his workspace he gets the following error: K03_UWGM_ACTION_NAME_MODIFYFORPRIVATE...never saw this one before.
Mar 1, 2017 5:40 PM UTC
What version/build, etc.
pkreiter1-VisitorAuthor
Mar 1, 2017 5:55 PM UTC
Windchill: 10.2 M030-CPS12
Creo: 3.0 M050
May 4, 2018 2:20 PM UTC
I had today a similar one:
Workspace Synchronization cannot be performed due to the conflict in File Name '<xxxxxxx_flat.prt>'
Workspace Refresh Failed in Action 'K03_UWGM_ACTION_NAME_UPLOAD'.
I've definitely seen this before, but can't find anything about it.  Strange.
May 21, 2018 1:46 PM UTC
A user in our company received a similar error today that I have never seen before, trying to figure out what is going on.
Workspace Refresh Failed in Action 'K03_UWGM_ACTION_NAME_ADD'.
11-Garnet
Jun 4, 2018 1:38 PM UTC
One of my users that I support also got the error : "Workspace Refresh Failed in Action 'K03_UWGM_ACTION_NAME_ADD'."
It seems as if the workspace somehow became corrupt and communication between Server and client-side workspaces somehow was affected.
The only way we could get it to work, was by deleting the workspace cache on the clients-side, and rebuilding it.
Oct 29, 2018 12:52 PM UTC
just experiencing the same with one user, getting this error message when trying "Add to workspace"
However, the objects (wtPart, cad models & assemblies & drawings) are found in the context root/default workspace, not the active one which was the target.
So, did you clear all caches on the Workstation in question and deleted the folder structure? That's it?
8-Gravel
Aug 21, 2018 9:02 AM UTC
one user had the same error while adding objects to workspace. (WC10.2 M030)
Tried adding from Standalone browser. it worked fine. when he did add to workspace in Creo session, he had the below error.
Then again we removed from workspace and tried adding in creo embedded browser. it is working fine.
Don't know why this error occurs
