May 6, 2021 3:55 PM UTC
What is the purpose of the ā€œSupplier Life Cycle Stateā€ - still selectable in MPN creation
What is the intended purpose of the ā€œSupplier Life Cycle Stateā€
Supplier is set to state = Cancelled
Still findable and more worse selectable?
Why can it be searched for and still be selected and assigned?
at MPN creation:
May 10, 2021 5:12 AM UTC
Hi Andreas
I am not sure what you mean with "no functionality". As I see, it is the same with other objects: CAD documents, wtdocuments, wtparts, ... Out of the box users have access to read objects in all states. Nothing prevent you from releasing a BOM with Obsolete/Cancel components at a lower level in the structure. This is where Business rules come into place.
It also depend om how you setup roles and ACL. Adding users to Product Managers they can do anything šŸ˜‰
BR
Johannes
May 7, 2021 10:28 AM UTC
Hi @ASodeik
With configuration of policy (ACL) you can remove users access to parts with Cancel state.
You could also configure a business rules when parts are released using change management. The business rule will check stated of "related" parts.
ASodeik1-VisitorAuthor
May 7, 2021 10:59 AM UTC
Thanks for the quick reply - the answer helps to go forward.
Out of the box the supplier life cycle state has no functionality? Correct?
Andreas
Hi Andreas
BR
Johannes
