3-Newcomer
Jun 20, 2023 7:54 PM UTC
What is the REST API to get Reference documents on a given WTDocument in Windchill?
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.0
I found a very similar QA on Java API but I want to know how to do it using REST:
https://www.ptc.com/en/support/article/CS183968
HelesicPetr
Jun 22, 2023 7:29 AM UTC
Hi @KD_10675014
In Windchill documentation on your system you have full restAPI documentation.
<server>/Windchill/netmarkets/html/wrs/doc.html
check all document rest functions and you can find lot of useful functions
Unfortunately I can not locate any function to retrieve a dependency link.
That means it may not exist.
PetrH
18-Opal
Jun 26, 2023 1:03 PM UTC
Hello KD_10675014,
I'm Charles from PTC Technical Support in Europe, I will provide you assistance on this question. Was the information provided helpful somehow?
KR,
Charles.
3-Newcomer
Jun 26, 2023 1:24 PM UTC
Thank you, Charles.
So far my problem is not solved. /Documents/PTC.DocMagmt.ReferenceDocument returns all reference documents. But that this not what I am looking for. PetrH also said that.
I am looking for a REST API endpoint that will return all reference documents for a given WTDocument.
I found a very similar QA on Java API but I want to know how to do it using REST or how to create a custom REST endpoint:
HelesicPetr
Jun 26, 2023 1:29 PM UTC
Hi @KD_10675014
Start to study this article CS183488 with many resources how to customize rest services.
Windchill REST Services User’s Guide point to the customization domains and this can help you.
Page 63 Examples for Customizing Domains
PetrH
