Oct 22, 2020 8:03 PM UTC
What's the use of User's Electronic Signature Image
In Windchill User Creation Wizard Option to Upload the Electronic Signature Image.
But there's no Use Cases for this Image or I'm not aware.
Anyone mention the use case of this?
HelesicPetr
Jan 11, 2022 8:11 AM UTC
You have to write own code to achieve that needs.
The example how to use API to get signature picture is
WTUser user = (WTUser) SessionHelper.getPrincipal(); // find user (in this example only logged user is used it is just for this example)
StandardOrganizationServicesManager stOrgmanager = StandardOrganizationServicesManager.newStandardOrganizationServicesManager();// create service manager to get signature
ElectronicSignature signature = stOrgmanager.getUserSignature(user); // get signature from user
ApplicationData adata = stOrgmanager.getUserSignatureApplicationData(signature); // get Application data where you can get picture of signature
Then you need to write a code to put the picture to existing PDF file in the system.
You can do it in a workflow but the workflow is limited to 4k characters in one robot.
PetrH
HelesicPetr
Dec 20, 2021 12:58 PM UTC
There could be customization Use Case.
You can use this Signature image as a signature for Drawing PDF output in PostPublish process that the signature is printed to the PDF page from approver user in the last finished promotion request(Any change process object could be used as you wish :D).
In our case a customer's manufactures wanted "hand sign" on the drawings so that was a way how to solve it.
Best Regards
PetrH
Navku14-AlexandriteAuthor
Jan 11, 2022 4:51 AM UTC
Hi Helesic,
Thanks for the reply.
Can you hint me how to use this signature in Drawing PDF.
Thanks again.
Navku
HelesicPetr
PetrH
