What to log to view queries to WindchillDS?
Hello!
We are using DPAs and have setup WindchillDS to host the MQ information about connection factores, destinations and such.
Aparently this is not working very well in a clustered environment.
It seems to work on slave nodes according to the logs but it fails with below exception when executed on the BGMS.
So my question is:
Which class/classes/tasks to activate in Log4j to view the requests/trafic to LDAP/WindchillDS?
Wed 12/4/13 16:30:43: SessionThread-6: ERROR : wt.adapter.exception Administrator - WTAdapterImpl
Wed 12/4/13 16:30:43: SessionThread-6: javax.naming.AuthenticationException: [LDAP: error code 49 - Invalid Credentials]
Wed 12/4/13 16:30:43: SessionThread-6: at com.sun.jndi.ldap.LdapCtx.mapErrorCode(LdapCtx.java:3067)
Wed 12/4/13 16:30:43: SessionThread-6: at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:3013)
Wed 12/4/13 16:30:43: SessionThread-6: at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2815)
Wed 12/4/13 16:30:43: SessionThread-6: at com.sun.jndi.ldap.LdapCtx.connect(LdapCtx.java:2729)
Wed 12/4/13 16:30:43: SessionThread-6: at com.sun.jndi.ldap.LdapCtx.<init>(LdapCtx.java:296)
Wed 12/4/13 16:30:43: SessionThread-6: at com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(LdapCtxFactory.java:175)
Wed 12/4/13 16:30:43: SessionThread-6: at com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(LdapCtxFactory.java:193)
Wed 12/4/13 16:30:43: SessionThread-6: at com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(LdapCtxFactory.java:136)
Wed 12/4/13 16:30:43: SessionThread-6: at com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(LdapCtxFactory.java:66)
Wed 12/4/13 16:30:43: SessionThread-6: at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:667)
Best regards,
Peter
